Parallella Community • View topic - Measuring power consumption
Postby adeshpande » Tue Jul 22, 2014 2:12 am
Is there any way to track how much power the board is using? (Or how much power the cores are using?)
adeshpande
Re: Measuring power consumption
Postby 9600 » Tue Jul 22, 2014 7:54 am
Yes, to measure how much power the board is consuming you would put an ammeter in series with the power supply, or use a power supply that has one built in.
If you wanted to measure how much power the Epiphany chip is consuming, you would have to intercept its power supply and I'm not sure if that is easily doable, but you could always take a look at the :)
AFAIK there isn't any capability within the Epiphany that would let you measure energy consumption at a core level.
If you are looking for a low cost and high accuracy / high sample rate energy measurement solution, I can recommend the (disclosure: I'm involved with the project).
Postby adeshpande » Tue Jul 22, 2014 4:35 pm
The MAGEEC project seems interesting. Does it measure the board power consumption or the chip power consumption?
adeshpande
Postby 9600 » Tue Jul 22, 2014 7:32 pm
Postby adeshpande » Mon Jul 28, 2014 2:48 pm
I found this link that shows how to measure the Epiphany chip power on a Parallella Prototype board.
http://www.adapteva.com/white-papers/me ... ype-board/
Is there any way we could do the same for one of these boards?
http://shop.adapteva.com/collections/fe ... p-computer
adeshpande
Postby timpart » Tue Jul 29, 2014 12:01 pm
Postby adeshpande » Tue Jul 29, 2014 1:41 pm
Hi TIm, thanks for the reply. I see that the Prototype Board uses makrings like TP2,TP4,TP9, etc. On my board, I hav similar but not those exact markings. I have TP12,TP13,TP14,TP15.
Do you think that there is any correlation or no?
adeshpande
Postby 9600 » Tue Jul 29, 2014 1:47 pm
Postby timpart » Wed Jul 30, 2014 5:49 pm
Postby baseballguy » Wed Jul 30, 2014 6:51 pm
And so what would TP2,TP4, and TP9 be? And what is the difference between those and the TP12,13,14,15?
Sorry, I think there is a link that has this information. Can someone direct me to it?
baseballguy
Users browsing this forum: No registered users and 34 guests
