won't boot what am I missing?
Posted: Mon Oct 20, 2014 5:39 am
I have followed the quick start guide. (Of which about 50% actually works)
after a couple hours of playing about attempting to burn an sd for my hdmi model parallela I finally have one with the ubuntu, the kernel copied in to BOOT, and the .bin file copied in to BOOT.
I have plugged in the hdmi in to the board and a t.v.
sd card is in the parallela
mouse and keyboard in to a hub connected to the usb near the power port.
and attempted to power up the board.
It powers up the lights. I can only see two because the heatsink is on it.
But for some reason I am getting no video output signal at all.
I made up the sd on ubuntu. Im having a hard time seeing what is wrong here. I don't have an Ethernet connection going to it but I wouldn't see that being a an issue that stops it from booting.
im using the power supply supplied with the unit.
I checked the sd and the rootfs and boot partitions are their and everything I would expect to be there is present.
Anyone got any ideas?
