Parallella Community • View topic - Using/downloading Android as OS
Re: Using/downloading Android as OS
Postby 9600 » Tue Sep 17, 2013 9:11 am
Postby awong209 » Tue Apr 29, 2014 8:38 pm
Just checked back on this old post of mine.
Wow what have I done??? It was my only intention of finding a way to get a common OS platform I would recognize realizing it will take awhile for someone to figure out how to configure it. Didn't intend for a firestorm. :oops:
awong209
Postby mrsteve » Fri Oct 24, 2014 11:50 am
Hi
I am creating an Android image for the Parallella board using the ZC702 xilinx Android example, i am using only the files provided by Xilinx for their board as a starting point. The Android image appears to boot and run and it looks like its only the HDMI that needs correcting. While booting the Xilinx image on the Parallella board i notice the following output in the serial debug console. The red text shows it trying to use the "parallellla.bit.bin" file, i haven't included this anywhere on the SD card or made any reference to it.
Is there some other bootloader (on a chip) on the parallel board besides the one on the SD card that is referencing the parallella.bit.bin?
Below is the output from the serial console.
U-Boot 2012.10-00003-g792c31c (Jan 03 2014 - 12:24:08)
I2C: ready
DRAM: 992 MiB
WARNING: Caches not enabled
MMC: SDHCI: 0
SF: Detected N25Q128 with page size 64 KiB, total 16 MiB
In: serial
Out: serial
Err: serial
Net: zynq_gem
Hit any key to stop autoboot: 0
Configuring PL and Booting Linux...
Device: SDHCI
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 4-bit
reading parallella.bit.bin
** Unable to read "parallella.bit.bin" from mmc 0:1 **
Error: Timeout waiting for FPGA to config.
fpga - loadable FPGA image support
Usage:
fpga [operation type] [device number] [image address] [image size]
fpga operations:
dump [dev] Load device to memory buffer
info [dev] list known device information
load [dev] [address] [size] Load device from memory buffer
loadb [dev] [address] [size] Load device from bitstream buffer (Xilinx only)
loadmk [dev] [address] Load device generated with mkimage
For loadmk operating on FIT format uImage address must include
subimage unit name in the form of addr:<subimg_uname>
reading uImage
4084344 bytes read
reading devicetree.dtb
mrsteve
Postby 9600 » Fri Oct 24, 2014 2:24 pm
