Parallella Community • View topic - A Beginners Guide to getting started with the Parallella.
Re: A Beginners Guide to getting started with the Parallella
Postby 9600 » Thu Aug 07, 2014 2:05 pm
It sounds promising if your router is successfully leasing the board an IP, but you should be able to then ping it and log in via SSH. Have you tried with the HDMI versions of the bitstream and kernel also? Shouldn't make a difference in theory, but not sure what else to suggest in this instance. Well, you could also take the SD card out and mount it on another machine and take a look at the logs.
Postby ajtravis » Sun Aug 10, 2014 9:41 pm
Postby AndyC » Mon Aug 11, 2014 7:07 pm
Hi Tony,
Thanks for the info.
A it off topic but I remember you were linking your boards via the network ports. Do you get gigabit connection, or just 100 mbit?
Cheers
Andy
AndyC
USB and NIC connections
Postby ajtravis » Mon Aug 11, 2014 10:11 pm
Postby AndyC » Tue Aug 12, 2014 5:45 am
AndyC
Postby ajtravis » Tue Aug 12, 2014 8:48 am
Postby AndyC » Tue Aug 12, 2014 9:03 am
Hi Tony,
This one http://www.amazon.co.uk/gp/product/B00D ... UTF8&psc=1 works for me.
Good luck!
Andy
AndyC
Postby FHuettig » Tue Aug 12, 2014 2:44 pm
Postby ajtravis » Tue Aug 12, 2014 11:49 pm
Postby FHuettig » Wed Aug 13, 2014 6:18 am
Users browsing this forum: Google [Bot] and 3 guests
