by SYOUYU » Wed Oct 01, 2014 9:18 am
Hi Andrew-san,
I checked the boot after 30min or more from the posting this thread.
Boot did not make the issue, but after 5min, black-out was frequently occurred and resolution issue was also happen.
It seems that a heating is issue, although I use a standard heat-sink.
Is it possible to make the issue by the temperature?
Anyway, USB is also issue now, not working.
I used bus-powered USB-Hub, and removed this hub and directly connected mouse to the board, but did not work
There is many threads about the USB issue, which one is best answer, or is there summarized thread for solution?
Best Regards,
SYOUYU
