Parallella Community • View topic - Boot stuck at 'Uncompressing Linux. done, booting the kernel
Postby madhavmurthy93 » Tue Oct 28, 2014 9:55 pm
madhavmurthy93
Re: Boot stuck at 'Uncompressing Linux. done, booting the ke
Postby madhavmurthy93 » Tue Oct 28, 2014 10:33 pm
I re-imaged the SD card with the kernel-headless-default and the FPGA file with NO HDMI display and decided to try booting the Parallella headless since I was not getting any output to the monitor. The output I got to the console was this:
Screen Shot 2014-10-28 at 3.20.23 pm.png (290.18 KiB) Viewed 33592 times
Based on this link: http://forums.parallella.org/viewtopic. ... +dtb#p8505 I need to modify the devicetree file. Is that right?
madhavmurthy93
Postby sebraa » Wed Oct 29, 2014 2:22 pm
The file system on your SD card seems to be corrupt. Apart from that, the log looks good - if you connect the ethernet port to a DHCP server, you should be able to connect to the board via SSH.
You do not need to modify the device-tree file unless you want to work/login through the serial console.
Postby pilgrim_kevin » Tue Nov 04, 2014 7:04 am
I have the same question. Any more suggestion?
BTW, before "U-Boot 2012.10-00003-g792c31c (Jan 03 2014 - 12:24:08)", there are some messy codes.
zynq-uboot> jÁL"¸€†Î@ˆì’€ærçpç™€Æ ƒæ€ÆðÆ€çÆ €ÆƒÆ€Œ€æÀÆ€p!!!!¥%áŒÖÙ}åÇ!Œ!á)¥!#t5YÙYÙÙÙÙtÙÙÙUÙÙÙÙdÙÉÉuÙÙÙÙdÙÙÙÍåÅ¡Œ!!3Å!!Œ'!)¥!çŒÑ!)å¥çjÝ!!ÝyÙÙÑt©f¥!
áÚ)¥!!L†%)¥!!Œ!!)¥!ÑtÙÙÙÝÙÙÙyt5„ÎÔÇÇáŒ!Q¥Ç!#Œ!!)¥Ç!!699!!Œ£!3¥áçŒ!29¥!áŽ!!)å&ŠÝ!!¥ÆáŒ!!)¥ùÙd]ÙÙ]ÙÙYÙTÙÉÉÙÙÙÙdéÙÉUÙÙÙÙtÉYyÙYÙÙtÙÉÙuÙÙ!¡t4)!¥%!\×!)¥!!\!!)å#!œ!ÙYÙÙÙÙtÙÙÙ]ÙÙÙÙdÙÙÙ]ÙÙçáŒÙÉÙ]ÙÙù#ä!!ÍÙYÙÙtÝ)—¹%¡Þ!!3Çá!,ÙÙ]ÝÙÙÙÙdÙ©ÙMYÙÙÙtÝÙ]u¥%ƒ¤)!]çãçç'Ù‘tÉYÙ]ÙYÙÙl×!)¥!!\„!)¥ Ùš!!1¥¡!Ü!ÙºZ!çŒ
I2C: ready
DRAM: 992 MiB
WARNING: Caches not enabled
MMC: SDHCI: 0
In: serial
Out: serial
Err: serial
Net: zynq_gem
Device: SDHCI
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading parallella.bit.bin
4045568 bytes read
reading uImage
4468792 bytes read
reading devicetree.dtb
8607 bytes read
Image Name: Linux-3.12.0-g0bc9c3a-dirty
Data Size: 4468728 Bytes = 4.3 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Loading Device Tree to 1fffa000, end 1ffff19e ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
pilgrim_kevin
Postby 9600 » Tue Nov 04, 2014 7:28 am
Postby gceline » Tue Nov 04, 2014 6:57 pm
This is correct behavior, the UART is turned off at this point. There is a way to reactivate this by re configuring the device tree - see this post viewtopic.php?f=48&t=1328&p=8505&hilit=UART+disabled#p8504
Graham
Adapteva
gceline
Postby duntonr » Fri Nov 21, 2014 7:56 pm
I am having this same issue after compiling the current main branch kernel from the parallella-linux repo. In my case though I am using TFTP boot and then mounting root fs via NFS.
Everything works using the standard binaries from http://www.parallella.org/create-sdcard/ (aside from a separate issue that i think might be a NSF over gigabit Ethernet problem. creating new topic on that separately)
I followed the great guide on elinux (http://elinux.org/TFTP_Boot_and_NFS_Root_Filesystems). This has you remove all the contents of the chosen block in the devicetree so that the board uses the bootargs that are passed up from the bootscript. I did still try 3 different devicetrees: 1) the one from create-sdcard page, 2) compiling one from the source (as noted here: https://github.com/parallella/parallella-bin) and 3) FHuettig's from viewtopic.php?f=50&t=1622&p=10037#p10037). All have same issue, eg sticking at "Uncompressing Linux. done, booting the kernel"
My bootargs are "setenv bootargs ${bootargs} console=ttyPS0,115200"
TR;DL: provided uBoot image works on TFTP boot, compiled uBoot image get stuck at "Uncompressing Linux. done, booting the kernel"
Kernel cross-compiled on Ubuntu 12.04 x86 VM (process adapted from: http://www.parallella.org/forums/viewto ... 65&p=10290) and no changes to .config, just strait from repo. Board is headless 7010 so WANT UART active all the time
Is there something else in the devicetree that needs to be updated, or maybe something else in bootargs or a kernal flag?
Below is the UART output:
PHY reset complete.
Waiting for PHY to complete auto-negotiation...
Link is now at 1000Mbps!
Using zynq_gem device
TFTP from server 10.10.100.10; our IP address is 10.10.100.2
Filename 'para_boot.scr'.
Load address: 0x100000
Loading: T #
done
Bytes transferred = 1154 (482 hex)
## Executing script at 00100000
Filename 'headless_7010/parallella.bit.bin'.
Load address: 0x4000000
Loading: #################################################################
done
Bytes transferred = 2083744 (1fcba0 hex)
Filename 'headless_7010/uImage'.
Load address: 0x3000000
done
Bytes transferred = 3349624 (331c78 hex)
Filename 'headless_7010/devicetree.dtb'.
Load address: 0x2a00000
Loading: ##
done
Bytes transferred = 6517 (1975 hex)
Image Name: Linux-3.14.12-parallella-xilinx-
Data Size: 3349560 Bytes = 3.2 MiB
OK
Loading Device Tree to 1fffb000, end 1ffff974 ... OK
Starting kernel ...
duntonr
Postby greytery » Sat Nov 22, 2014 12:44 pm
Postby duntonr » Sun Nov 23, 2014 4:05 pm
duntonr
Postby duntonr » Sun Nov 23, 2014 4:36 pm
boot script is
setenv tftp_dir headless_7010
setenv nfs_rfs /files/nfs/para_nano_1410
setenv bootargs ip=dhcp
setenv nfs_ip 10.10.100.10
setenv bootargs ${bootargs} rootwait root=/dev/nfs rw nfsroot=${nfs_ip}:${nfs_rfs} ${ip}
setenv fpga_image parallella.bit.bin
setenv fpga_addr 0x4000000
setenv fpga_size 0x3dbafc
setenv fpga_tftp 'tftpboot ${fpga_addr} ${tftp_dir}/${fpga_image}'
setenv fpga_load 'fpga load 0 ${fpga_addr} ${fpga_size}'
setenv fdt_image devicetree.dtb
setenv fdt_addr 0x2A00000
setenv fdt_tftp 'tftpboot ${fdt_addr} ${tftp_dir}/${fdt_image}'
setenv kernel_image uImage
setenv kernel_addr 0x3000000
setenv kernel_tftp 'tftpboot ${kernel_addr} ${tftp_dir}/${kernel_image}'
setenv phy_rst 'mw.w f8000008 df0d ; mw.w f8000140 00100801 ; mw.w f8000004 767b'
setenv rset_phy 'run phy_rst'
setenv boot_now 'bootm ${kernel_addr} - ${fdt_addr}'
run fpga_tftp fpga_load kernel_tftp fdt_tftp rset_phy boot_now
duntonr
