Parallella Community • View topic - Automating an SDK build
Postby snim2 » Fri Oct 31, 2014 10:15 am
snim2
Re: Automating an SDK build
Postby snim2 » Sat Nov 01, 2014 7:54 pm
In case it is helpful, I have pasted the output of that BASH script here:
Sarah
snim2
Postby SYOUYU » Fri Nov 14, 2014 1:22 am
Hi All,
I also made auto-build script file.
but it meets an error of;
Epiphany toolchain not found on build machine
first,
sudo ./sdk/build-epiphany-sdk.sh -C -R -a x86_64
is successfully done, but second;
is not.
Do you know how solving this issue?
Thanks and Regards,
SYOUYU
Best Regards,
SYOUYU
SYOUYU
Postby SYOUYU » Fri Nov 14, 2014 1:11 pm
Best Regards,
SYOUYU
SYOUYU
Postby SYOUYU » Sat Nov 15, 2014 11:41 am
Best Regards,
SYOUYU
SYOUYU
Postby snim2 » Thu Jan 29, 2015 7:28 am
snim2
Postby peteasa » Fri Jan 30, 2015 5:26 pm
I have been working on a yocto environment. What is missing is a re-arrangement of the Makefiles in the epiphany-libs (https://github.com/adapteva/epiphany-libs) to be yocto friendly. I might get round to doing that at some point so that you can build epiphany-libs from source. Once done the yocto environment will build a distribution for the prototype board so you can use smart update to update packages, it will also produce an SDK so that you can use yocto eclipse or any IDE to develop epiphany code and then copy this to the board, it will also produce a complete SD card image so that you can boot the board from sd card. Follow the progress of this project at viewtopic.php?f=9&t=414.
The script at https://github.com/peteasa/parallella-yoctobuild builds all the compilers and cross compilers you need today. It is also can be configured to use the prebuilt epiphany-sdk with the yocto build. As mentioned the only thing missing now is the build epiphany-libs from source... a relatively simple step if you know yocto!
Peter
peteasa
Postby snim2 » Sat Jan 31, 2015 5:32 pm
snim2
Postby peteasa » Sat Jan 31, 2015 8:18 pm
peteasa
Postby peteasa » Sat Feb 07, 2015 8:43 pm
peteasa
