Parallella Community • View topic - ePython error on first run for multicore code
Postby GlasierXplor » Tue May 09, 2017 3:51 pm
GlasierXplor
Re: ePython error on first run for multicore code
Postby polas » Tue May 09, 2017 11:41 pm
Hi - I am sorry you are having difficulties with this. Is this the preinstalled ePython on the latest OS image distro or a version you have installed from the Git repo yourself? Are you using the latest OS image, or is this an older image? What command are you using to launch ePython?
Nick
polas
Postby GlasierXplor » Wed May 10, 2017 7:46 am
Hi!
I tried running stock ePython from Parabuntu 15.04 (latest image), by using `epython code.py`. I got and error saying that `parallel.py cannot be found`.
So I thought that there might be some problem with the ePython, so I downloaded it from Git. After installing, and running again using `epython code.py`, I got the error I mentioned in my first post.
Thank you for helping!
GlasierXplor
Postby sebraa » Wed May 10, 2017 9:28 am
Can you try running it like "sudo epython code.py"?
Postby GlasierXplor » Wed May 10, 2017 9:32 am
GlasierXplor
Postby polas » Wed May 10, 2017 3:13 pm
polas
Postby olajep » Fri May 12, 2017 1:41 pm
Postby GlasierXplor » Sat May 13, 2017 4:01 pm
GlasierXplor
Postby GlasierXplor » Sat May 13, 2017 4:07 pm
GlasierXplor
Postby olajep » Sat May 13, 2017 7:47 pm
Users browsing this forum: Google [Bot] and 7 guests
