Parallella Community • View topic - Cooling stand for Parallella cluster
Postby jeremybennett » Fri Mar 28, 2014 7:29 pm
The Parallella cluster stack packs 144 processors and 200 GFlops into a space of approximately 150x86x54mm. While the Epiphany processors are very low power, the Zynq FPGAs hosting the ARM cores and glue logic get warm and need cooling.
I've published a design on which provides a holder for two 120mm fans to force air across the FPGA heat sinks of the entire stack. The design is configurable to allow for different size fans. We produced ours using a RepRap Prusa-Mendel 3D printer. It is effective at keeping the FGPA to around 50C, even in a warm office.
Enjoy.
jeremybennett
Re: Cooling stand for Parallella cluster
Postby aolofsson » Fri Mar 28, 2014 8:14 pm
Jeremy,
Awesome. Very impressive...and from a software compiler expert nonetheless.:-)
Postby ubii » Fri Mar 28, 2014 9:46 pm
Nice setup, now all I need is 7 more boards, to justify building this cooling stand. ;)
ubii
Postby shodruk » Sat Mar 29, 2014 12:48 pm
That's wild and cool!! 8-)
