Parallella Community • View topic - Ideas for daughter cards?
Re: Ideas for daughter cards?
Postby Tomo » Sat Sep 07, 2013 1:52 pm
A daughter card with additional memory would definitely be needed. Cheap and fast storage.
Could the card connect to south or north link so that epiphany cores would get direct connection to ram and would then not need 10+ cycles to access it. It would be faster than included 1Gb memory which has 10+ latency.
The question is how to connect eMesh network to the ram chips. Maybe in the future the epiphany card could have west link which is opposed to the fpga connection of the Zynq chip. You could have Zynq chip sending data -> going trough a few epiphany cores (prefilter...) -> RAM. Then do some other stuff (Zynq chip <-> epiphany cores) and after that apply afterfilter:
RAM -> epiphany cores(afterfilter) -> Zynq chip -> disk/netwok ...etc.
Also there is a need for sata 3 connector ( or even sata 4 - SSD). For large data computation it would be cheaper to have a disk directly on the epiphany card.
One additional thing comes to my mind to be able to use speed of the processors - sfp+ connector implement fibre optic cable. You could then connect epiphany modules over fibre - using the speed of 10Gbps over several miles. Encroaching on the territory of the high end router. Sfp+ connector implemented over fpga would be interesting.
Tomo
Postby Gravis » Sat Sep 07, 2013 10:04 pm
Postby stealthpaladin » Wed Sep 18, 2013 6:23 pm
stealthpaladin
Postby Gravis » Wed Sep 18, 2013 10:14 pm
Postby drewski » Wed Sep 25, 2013 1:14 pm
drewski
Postby stealthpaladin » Mon Sep 30, 2013 11:25 am
stealthpaladin
Postby doddy1985 » Wed Oct 09, 2013 9:38 pm
Expansion for extra microSD storage :)
doddy1985
Postby Morgaine » Fri Oct 11, 2013 7:39 am
Morgaine
Postby tnt » Fri Oct 11, 2013 8:11 am
Although there are some good ideas in there, there are a few practical points that are also far from ideal:
- Gigabit is not that high data throughput ... The FPGA link has 24 pairs where you can do >500 Mbps on each pin, so that's >6 GBps full duplex (or even 12 GBps in one direction if your application is not balanced).
- Gigabit is not that easy to use. To convert a fast LVDS pair into IO I can connect directy to plenty of things, I just need a <5$ LVDS ser-des chip. Gigabit is infinitely more complex than that ... (not even speaking of higher protocol you'd come up with to share the bus and the 'switch' you'd need to have to connect several modules to it)
- Backplane type of interconnect make it hard to maintain a tiny / pocket sized form-factor
Personally I'm interested in that board for low power, compact-ness and the fact the fpga can be used as the glue-logic between the ARM+Epiphany and whatever device I want to connect to. If I wanted something PC-like, I'd use a PC ...
Postby Morgaine » Fri Oct 11, 2013 9:07 am
Morgaine
