Parallella Community • View topic - Memory allocation problems in epiphany chip
Postby omar » Fri Mar 13, 2015 3:48 pm
omar
Re: Memory allocation problems in epiphany chip
Postby piotr5 » Fri Mar 13, 2015 7:27 pm
yes. allocate mem for hashTable. then allocate mem for each node you create. also allocate enough space for the "node **lists" to store all the pointers contained in hashTable. i.e. "lists" isn't contained in hashTable as you claim, you need to treat it as if it were just a reference to an array of pointers you have to create manually. or did you mean lists to point inside of the int-array node.arr?
piotr5
Postby omar » Fri Mar 13, 2015 11:16 pm
omar
Postby piotr5 » Sat Mar 14, 2015 8:47 am
haven't looked at the details, so my view might be unjustified: I'm not sure how your approach actually could work. on one core you allocate space and then free it on another core. does that really work? if there is an allocation-table in shared memory, wouldn't that cause trouble once you communicate through eLink north/south? imho you need to create your own memory-manager. it's suspicious that you are using the command free() and not whatever found in eSDK...
piotr5
