Parallella Community • View topic - call the epiphany program many times without e_reset
Re: call the epiphany program many times without e_reset
Postby sebraa » Thu Nov 05, 2015 3:04 pm
Postby MiguelTasende » Thu Nov 05, 2015 4:05 pm
MiguelTasende
Postby sebraa » Fri Nov 06, 2015 12:29 am
Okay... so you are developing a library, which provides Epiphany-services to some (to the library unknown) application.
You could still use the same principle: Before your application can run ANY Epiphany-accelerated kernel, it has to initialize the library (which wraps e_init() and e_open(), and possibly memory management etc), and after it is done with ALL actions, it needs to deinitialize the library (which would wrap e_finalize()).
You could also make this transparent, by having the library keeping track of whether this has been done (or use constructor/destructor to make this automatic). Accelerating a function (that is, loading a kernel) then is just { trap core, e_load(), untrap core, monitor state }. However, this still assumes that one application wants to - during its lifetime - call the Epiphany multiple times.
If this isn't possible, I would think that you need some kind of delay between calling e_finalize() and e_init(), to make sure that all eLink transactions have been completed (or failed). It might help to manually trap all cores before calling e_finalize(), to make sure that no eLink transactions are possible. Unfortunately, the eLink interface is prone to crashing the whole system if provoked. :-(
Postby MiguelTasende » Fri Nov 06, 2015 7:03 pm
MiguelTasende
Postby sebraa » Sat Nov 07, 2015 2:56 pm
With trapping a core I mean "putting a core in halt mode". This is done by running a "TRAP nn" instruction (n is a number from 0 to 63), or by writing 0x1 to the core's DEBUGCMD register (address 0xF0448). To untrap, write 0x0 to the DEBUGCMD register.
So the idea is to never call e_open() again, instead:
- trap all cores
- call e_load() with the new kernel
- untrap all cores (maybe not needed)
