Sensor charatization
hi!
just to describe my scenario, I'm trying to use Parallella with some sensors that need characterization, I mean a cycle of readings within 2/3 physical conditions in order to have a 3D table of points each, once as its own peculiar calibration.
When real readings must occur, the linear regression in between of the right cube within the 3D matrix of calibration must be got out.
Well, far from my final result, I have created my host.c code and my e-device.c code.
As optimized output I need to use ncurses library with my e-device.c code in order to show results of my cores working in parallel at fixed position on my ssh remote terminal.
Well , my trouble and my request for help:
I am in trouble to link -lncurses and my curses.h.
No way adding to e-gcc command line the -L/lib/arm-gnuxxxx and -I/usr/lib in order to make ld link the library using the headers.
What am I missing, if anybody coukd help me?
I'm attempting to use the epiphany-examples/apps source code but unsuccessfully.
my best and thanks in advance
