Advantages of different methods of connecting boards
Posted:
Wed Jun 03, 2015 5:47 pm
by jahorin
It seems like in terms of interconnecting multiple parallella boards, there is a variety of options and ways to do so. Just speculation from most of the cluster projects I've seen, the most common seems to be connecting power supply through the mounting holes with J15 shorted and then using ethernet cables with a switch to go from there. What I haven't seen as much is connecting using the PEC's between boards. My question then I guess is, what is the most dependable way of connecting boards to create a cluster?
Re: Advantages of different methods of connecting boards
Posted:
Thu Jun 04, 2015 4:36 pm
by 9600
AFAIK the only method that has really been tested is using Ethernet. Although I'd be interesting in hearing from anyone who connects their boards together via PEC_NORTH and PEC_SOUTH. Of course, you could also use PEC_FPGA also if you implemented some sort of controller in the PL.
Posted:
Thu Jun 04, 2015 5:47 pm
by jahorin
Andrew,
Thank you for the reply. I saw aolofsson's comment this morning about the Porcupine boards () and I might try to snag a few when they become available. Otherwise it seems like just making eLink cables from buying the connectors from samtec (BTH-030-01-F-D-A) and soldering ribbon cable is a possibility- if only I trusted my (very limited) soldering skills to do the job.
For anyone- has there been any word on when eLink cables will become available to purchase? I've seen the question asked a few times and don't know if I've seen an answer.
-Jay
Posted:
Thu Jun 04, 2015 6:35 pm
by 9600
Posted:
Fri Jun 05, 2015 7:27 am
by piotr5
