Two Parallellas eLink cluster (interconnected)
Posted:
Wed Sep 13, 2017 9:18 am
by claudio4parallella
Re: Two Parallellas eLink cluster (interconnected)
Posted:
Wed Sep 13, 2017 1:37 pm
by jar
These are probably questions for Ola, directly.
Regarding #1, I can only suggest that it looks like the functionality was not needed in newer versions. Ola left comments to that effect:
https://github.com/adapteva/epiphany-li ... geLog#L561
Posted:
Wed Sep 13, 2017 8:11 pm
Thank you very much jar for your reply.
I'm realizing that my questions were badly asked.
1. it seems that the nnew release doesn't need any more that address initialization.
Could anybody confirm that this value has nothing to do with my attempt?
2. any suggestion about how to change 32 to 36 as needed for the two elink interconnected parallellas ?
peteasa and others have written many things here in the far past but I have not been so smart to understing every step or repeat these steps with the last image and sdk relase
thank for any help, my best
Posted:
Sat Sep 16, 2017 1:42 pm
by olajep
Posted:
Sun Sep 17, 2017 10:30 am
Posted:
Sat Sep 23, 2017 6:56 am
It does work !
with esdk.2015.1
Now I'd like to port it to esdk.2016.1
Posted:
Fri Nov 10, 2017 5:52 pm
by dejan
Where did you buy eLink (cables)?? I was looking for it everywhere! I have my old parallella kit (4 boards) and I would like to connect them using eLink, but have no idea where to buy the cables!??
Posted:
Sun Nov 12, 2017 8:30 pm
@dejan
Have a look at this post, I've explained my eLink cluster project starting from BillOfMaterial and links where to find all the items.
All according to an experience that was documented years ago using 2014 ParaUbuntu Image.
You could help me trying to port the cluster to last ParaUbuntu image 2017.11 .... will you?
Well, about cables you have two alternatives:
1 - purchase the Parallella eLink cables here already done (18 Pounds plus shipment)
2 - purchase >40 flat cable (of 1mm, not standard 1.27mm) and the 40 pin female plugs. It's easy to press the flat cable to grip the contacts
Let me know about your progress, keep us in touch!
Posted:
Mon Nov 13, 2017 2:57 pm
by dejan
I do not have the porcupine board...
Posted:
Mon Nov 13, 2017 5:55 pm
without a Porcupine (
http://www.digikey.com @ 35$), you need this DIY...
