Took a long vacation to switch jobs and move to the different country
On the compiler side - working on vectorization, or strd/ldrd to be precise, plus i64/f64 support. Atm most tests build fine, and actually arithmetic runs a bit faster than on GCC (not much, as i'm still using precompiled libs from gcc bundle). I want to fix matmul-16 test which fails on memory mapping (sections overlap) before moving on.
Another big question is CI and distribution. Travis has build time limitation of 1 hour, which is not enough to build full LLVM stack, and ccache size of 512 mb, which is not enough to use ccache with LLVM build. Semaphore has disk quote, which is also too small to fit the build. Will try to look for solution, or maybe i'll just mail Semaphore or Travis and ask them to raise quote for my build (iirc they're ok doing it for FOSS projects
