Parallella Community • View topic - Parallella Ubuntu 14.04 release
Re: Parallella Ubuntu 14.04 release
Postby g3vbv » Tue Jul 15, 2014 3:35 pm
backer number is 2118
I am checking to see which 14.04 image to download, whether 7010 of 7020 as the heatsink hides the ZYNQ.
Retired - Senior Staff Specialist Amdahl worldwide supporting AMDAHL/Fujitsu/IBM Mainframes and Sun/Fujitsu SPARC servers.
g3vbv
Postby 9600 » Tue Jul 15, 2014 3:37 pm
Postby g3vbv » Tue Jul 15, 2014 4:10 pm
g3vbv
Postby maynarde » Sat Jul 19, 2014 8:37 pm
July 19,2014
Trying to get my Parallella up and running. This would be a 7010 chip with the large heatsink already in the box. Followed the Linux SD build instructions using the 6/11 linked Ubuntu image, the headless kernel files. Initially boot failed at:
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
TCP: cubic registered
NET: Registered protocol family 17
Registering SWP/SWPB emulation handler
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
ALSA device list:
No soundcards found.
EXT4-fs (mmcblk0p2): recovery complete
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Freeing unused kernel memory: 188K (c0878000 - c08a7000)
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
▒▒+▒▒ plymouth-upstart-bridge main process ended, respawningwith status 1
but then it got through to:
ALSA device list:
Starting fake hwclock: loading system time.ended, respawningwith status 1
Current system time: 2014-06-11 13:17:14
fake-hwclock saved clock information is in the past: 2014-06-11 13:17:01
To set system time to this saved clock anyway, use "force"
* Setting up X socket directories... [ OK ]
LEDs are not blinking and the heatsink is doing its job (warm). I am not a Linux pro so any ideas what I should try next? I will try the HDMI versions for giggles.
maynarde
Postby 9600 » Sun Jul 20, 2014 10:34 am
Just to be sure that you use the headless kernel and FPGA bitstream, or the HDMI kernel and bitstream, but not a mismatch of the two.
Can you try to log in via SSH (ascertain IP from your router). And if your board is not getting an IP address, you can try mounting the SD card's root filesystem from another computer and deleting the file:
etc/udev/rules.d/70-persistent-net.rules
Then unmount the SD card, reinsert into the board, boot and see if it gets leased an IP address.
Postby maynarde » Sun Jul 20, 2014 7:10 pm
Not mixing and matching bitstreams. Seems to be hanging on the hardware clock (different from the RTC) - went through that step once before hanging up. I will get the necessary pieces of hardware to run the HDMI setup and see what happens.
maynarde
Postby 9600 » Sun Jul 20, 2014 7:35 pm
OK, let me know how you get on with the HDMI config. May even be worth trying it without a monitor and keyboard etc. to see if it's any different / you can SSH in.
Postby maynarde » Sun Jul 20, 2014 8:39 pm
i have been trying the headless configuration with the UART enabled and cannot get to a login prompt. Are you suggesting that SSH is already installed? If that were true, I could disable the UART (as in some other threads) in the device tree and use ethernet to get in. How about a wifi dongle? I have been using that with my RPi and BBB successfully. Let me know if SSH is going to be there to try (still very noobie on linux). Thanks in advance for the help.
maynarde
Postby 9600 » Mon Jul 21, 2014 6:03 pm
The SSH server software should be installed and you don't need to disable the UART in order to connect via SSH.
If you connect your board to the network booting, power it up and then a few minutes later log in to your router to see if it has leased an IP address to the board via DHCP. Once you know the address you can then SSH in via the user "linaro".
Postby maynarde » Mon Jul 21, 2014 7:31 pm
Excellent. I will try that tonight. HDMI adapter is on order (need to get to VGA - I know, I know, old monitor) so I should be able to try that next week.
maynarde
