Need help creating parallella.bit.bin
Hi.
I'm trying to boot Ubuntu headless image with a custom FPGA configuration.
I've done the following steps:
1) Used Win32 Disk Imager to flash an SD-card with the latest Ubuntu 14.04 Parallella (Zynq7020) headless image.
2) Logged in the terminal with MobaXterm. - Everything works fine
3) Downloaded FSBL.elf and u-boot.elf from: https://github.com/parallella/parallella-flash.
4) Used Vivado 2014.3.1 to generate a bitstream from the parallella_7020_headless.xpr.zip project, which can be found here: https://github.com/parallella/parallell ... o/releases.
5) Exported everything to SDK and used the "create zynq boot image" tool to bundle FSBL.elf, elink2_top_wrapper.bit, and u-boot.elf into parallella.bit.bin (in this exact order).
6) Replaced the parallella.bit.bin file on my SD-card with the one I've just made. Did not change devicetree.dtb and uImage.
7) Tried to log in with MobaXterm. - No success
Advanced IP Scanner doesn't even find the device.
What am I missing?
Please help.
What am I missing?
Please help.
