Page 1 of 2
How to run a "self-test" of the Epiphany chip
Posted:
Wed Mar 26, 2014 10:00 pm
by aolofsson
At least one of you have reported issues with the Epiphany chips on your Parallella board. The "test.sh" is a great demo application, but it doesn't help find what the root problem might be. The following program runs a variety of tests (more coming...) to help diagnose the issue.
Use:e-test
Code Location:https://github.com/adapteva/epiphany-ex ... pps/e-test
Re: How to run a "self-test" of the Epiphany chip
Posted:
Wed Mar 26, 2014 10:42 pm
by ubii
aolofsson,
It appears that the build script for e-test is failing due to two separate issues. First, the "bin" directory does not exist by default, so you may want to add "mkdir -p bin/", like you have in other build scripts. Second, it appears as though "src/test_memory_dram.c" is missing, so the build script is unable to create the associated elf file.
Posted:
Thu Mar 27, 2014 11:48 am
by aolofsson
ubii, Thanks!! Fixed
I will test in a clean directory, I will test in a clean directory, I will test in a clean directory, ...
Posted:
Thu Mar 27, 2014 2:12 pm
by ubii
aolofsson,
Thank you for resolving this issue so quickly, I am now able to run e-test, as seen below.
***Running Simple Memory Test***
***Running March-C Memory Test***
***Running Host Read/Write Test***
***Running DRAM Read/Write Test***
***Running Emesh Test***
***Running Simple Matmul Test***
GOOD: CHIP PASSED SELF-TEST!
Posted:
Thu Mar 27, 2014 2:36 pm
by aolofsson
Great to hear! Thanks!
Posted:
Sat Aug 09, 2014 9:23 pm
by spanier
I have been having some difficulties getting the self tests to run without early crashing and locking up my Parallella E64 board.
However, I have managed to run the self tests within epiphany-examples.git/archive/e-test. Note, I run each test separately, otherwise it gets stuck in an infinite loop with the default run all tests option.
I did find that the distribution needed editing for the Parallella board (bsps directory) as some files were missing... I am documenting all the little gotchas elsewhere. What would be a useful place to mention them ? .. or on github ?
Anyway, here are my results from the archive directory (testing backwards):
Running DRAM read/write test for all cores
Running emesh test for all cores
Running simple matmul test for all cores
GOOD: E64G401 PASSED SELF-TEST! (note I did not edit any of the code and think this might be incorrect)
Running march-C memory test for all cores
...waiting for core (0,0)
FAILED for core (4,0)
FAILED for core (4,4)
BAD: CHIP FAILED!!!!
Running simple memory test for all cores
Testing elink from core (0,0)
Running host read/write test for all cores
FAIL (6,7) k=3763 data=aabaaaaa
FAIL (6,7) k=3779 data=aabaaaaa
FAIL (7,1) k=3420 data=a8aaaaaa
FAIL (7,7) k=1336 data=55554555
So, it looks like my 64 cores are actually 59 with suspects of (4,0), (4,4), (6,7), (7,1) and (7,7)
Anyway, I will keep you posted on my experiments....
Regards
Jonathan
Posted:
Sat Aug 09, 2014 9:37 pm
by spanier
Hello again
For completeness this is what happens with the standard epiphany-examples.git/test:
1. set e-toggle-led to 1 - detect if system hangs
2. EPIPHANY_TESTS environment variable set to the local epiphany-examples git directory
3. ./scripts/TestEpiphany.pl -l scripts/LIST.E64 -skip scripts/SKIP.LIST -d run -rows 8 -cols 8
Results:
Running /home/linaro/epiphany-examples/test/e-reset/test.sh PASSED
Running /home/linaro/epiphany-examples/test/e-write-word/test.sh PASSED
Running /home/linaro/epiphany-examples/test/e-read-word/test.sh PASSED
Running /home/linaro/epiphany-examples/test/e-write-buf/test.sh PASSED
Running /home/linaro/epiphany-examples/test/e-read-buf/test.sh
Yes, the red epiphany led goes out, ethernet dies, HDMI dies - needs to power cycle or press the reset button to resurrect the board. Also, any log files won't have anything saved using the standard framework.
So, this is where I am at at the moment.
Posted:
Thu Mar 12, 2015 6:42 pm
by BOBNINO
I can't seem to get ubuntu 14 up on my screen, i tried using startx but only get the parallella logo and not ubuntu, secondly every time i use xrandr i get cannot open display !! I'm using it with a TV and the text on the TV fades away on the side of the screen and i cant readjust it from my TV , any solutions??
Posted:
Thu Mar 12, 2015 6:59 pm
by 9600
I'd suggest trying alternative displays.
Posted:
Sun Mar 15, 2015 4:47 pm
by BOBNINO
thanx buad 9600 i fixed it , had to find the right user for the x server.
