How to expand the Linaro image to fill your SD card
First off you'll need to create the device points for SD card access:
sudo mknod -m 660 /dev/mmcblk0 b 179 0
sudo mknod -m 660 /dev/mmcblk0p1 b 179 1
sudo mknod -m 660 /dev/mmcblk0p2 b 179 2
Once done you can use fdisk to resize the disk:
sudo fdisk /dev/mmcblk0
Command (m for help): p
Disk /dev/mmcblk0: 15.9 GB, 15931539456 bytes
4 heads, 16 sectors/track, 486192 cylinders, total 31116288 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00056828
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 2048 264191 131072 b W95 FAT32
/dev/mmcblk0p2 264192 31116287 15426048 83 Linux
Command (m for help): d
Partition number (1-4): 2
Command (m for help): n
Partition type:
p primary (1 primary, 0 extended, 3 free)
e extended
Select (default p): p
Partition number (1-4, default 2): 2
First sector (264192-31116287, default 264192):
Using default value 264192
Last sector, +sectors or +size{K,M,G} (264192-31116287, default 31116287):
Using default value 31116287
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
WARNING: Re-reading the partition table failed with error 16: Device or resource busy.
The kernel still uses the old table. The new table will be used at
the next reboot or after you run partprobe(8) or kpartx(8)
Syncing disks.
linaro-nano:~>
Now reboot your device:
sudo reboot
Lastly run the resize tool on the root partition:
sudo resize2fs /dev/mmcblkp2
Enjoy all the extra space!
Partition type:
e extended
Syncing disks.
linaro-nano:~>
sudo reboot
