Page 10 of 11
Posted:
Sat May 10, 2014 8:16 pm
by xilman
Assuming my Parallella eventually arrives, I'll initially be studying and, I hope, learning.
Longer term it should fit into my interests in image processing, computational chemistry and computational number theory.
Posted:
Mon May 26, 2014 12:17 pm
by eleitl
Learning parallel programming, and writing MD and spiking neural code for Epiphany clusters.
Posted:
Sun Jun 15, 2014 6:00 am
by toddb
Been using mine for a synth/effects project, my original goal was to do simulation/research but after migrating to a newer notebook that task had been filled.
Posted:
Sat Aug 30, 2014 8:26 am
by Grumpy Old Coot
My realistic plans:
- Spend a lot of hours reading and tinkering with software prior to even ordering a Parallella-16 Embedded.
- Get the OS running.
- Figure out how to actually use the ZYNQ FPGA without killing the Parallella-16.
- Figure out how to actually use the Parallella-16.
- Kit-bash together the Porcupine and a couple other ideas.
- Learn.
My unrealistic plans:
- AUV "brain" fixed-wing board with an ungodly amount of processing power and sensors talking over a ISM R/F link to a Radxa Rock Pro base station.
Posted:
Mon Jun 01, 2015 1:26 pm
by hmeftah
DevOps training course support using Docker containers as baseline technical architecture.
Posted:
Tue Jun 02, 2015 8:05 pm
by capnrob97
Ordered a desktop board from Amazon yesterday, getting it tomorrow.
Will play around with it at first, then start thinking of coding projects to do on it.
I do have code that pulls ADS/B data off of two receivers and displays it in curses I have running on my Mac OS/X, will probably move that code over as a start.
Posted:
Mon Jun 15, 2015 10:15 pm
by capnrob97
Been playing around with nbody astro sim I pieced together, here is one running on parallella with 2 'mega' stars with 100,000 times the mass of the others.
Posted:
Fri Jun 19, 2015 8:36 pm
by capnrob97
Latest vid, a 850 star system collapsing on itself.
I am really enjoying playing with this, still no sure about the memory map though, but I will get there.
Fixed a star 'slingshot issue' the softening constant not large enough.
Posted:
Fri Jun 19, 2015 9:37 pm
by aolofsson
Music to my ears! Really happy to hear that you are enjoying the board! Did you see the following recent source code publication?
I think they are running pretty fast?
https://github.com/USArmyResearchLab/mpi-epiphany
Posted:
Sat Jun 20, 2015 4:45 pm
by capnrob97
