Parallella Community • View topic - COPRTHR 2 Discussion
Re: COPRTHR 2 Discussion
Postby jar » Thu Jun 09, 2016 7:47 pm
mjvbhaskar1000,
If you are trying to use COPRTHR-2 on the latest headless installation (2016.3), you're on your own. I really doubt it will work. You should use the 2015.1 image if you want to use COPRTHR-2. If you are reading this weeks or months from now, maybe it will be supported on 2016.3.
Postby mjvbhaskar1000 » Thu Jun 09, 2016 8:42 pm
jar,
Thanks a lot for the information.
I will try installing
https://github.com/parallella/pubuntu/r ... 1-20150130
and check.
Also is this the image you were referring to?
mjvbhaskar1000
Postby jar » Thu Jun 09, 2016 8:56 pm
Postby jar » Fri Jun 10, 2016 7:37 pm
For those of you using the MPI examples, to work with COPRTHR-2.
Note: there seems to be a regression with the stencil code so that it locks up.
Postby mjvbhaskar1000 » Fri Jun 10, 2016 10:23 pm
mjvbhaskar1000
Postby jar » Sat Jun 11, 2016 5:29 am
Postby mjvbhaskar1000 » Tue Jun 14, 2016 3:18 pm
Thanks a lot. I started a fresh installation and it worked.
mjvbhaskar1000
Postby mjvbhaskar1000 » Wed Jun 15, 2016 7:49 pm
Last edited by mjvbhaskar1000 on Thu Jun 16, 2016 3:30 pm, edited 1 time in total.
mjvbhaskar1000
Postby jar » Wed Jun 15, 2016 8:13 pm
Postby nickoppen » Thu Jun 16, 2016 11:31 am
nickoppen
Users browsing this forum: Google [Bot] and 5 guests
