Parallella Community • View topic - Issues with ubuntu-14.01-lxde.14.03.06
Postby shodruk » Sat Mar 08, 2014 10:04 am
ubuntu-14.01-lxde.14.03.06 issues
Re: Issues with ubuntu-14.01-lxde.14.03.06
Postby shodruk » Sat Mar 08, 2014 10:16 am
1. Cannot configure network settings
temporary solution: sudo nm-connection-editor
2. xrandr won't work properly
Postby shodruk » Sat Mar 08, 2014 12:25 pm
Issue:
No sound.
Temporary solution:
$ sudo mkdir /dev/snd
$ sudo mknod -m 660 /dev/snd/controlC0 c 116 0
$ sudo mknod -m 660 /dev/snd/pcmC0D0p c 116 16
$ sudo mknod -m 660 /dev/snd/timer c 116 33
$ sudo chown root:audio /dev/snd/*
nano ~/.asoundrc
---- cut here ----
pcm.!default {
type rate
slave {
pcm "hw:0"
rate 48000
converter "samplerate"
---- cut here ----
Postby aolofsson » Sat Mar 08, 2014 12:30 pm
shodruk,
Thanks for posting the issues!! We will work on resolving these issues asap. What do you think about using the built in github issue manager for some of these?
https://github.com/parallella/parallella-ubuntu/issues
Postby shodruk » Sat Mar 08, 2014 12:45 pm
Thanks. I'll try that.
Postby shodruk » Fri Mar 14, 2014 7:02 pm
In ubuntu-lxde-14.03.06-p16g1.img.gz,
There are some minor file system errors in the BOOT partition.
Postby appleiiguy » Fri Mar 21, 2014 11:56 pm
appleiiguy
Postby shodruk » Sat Mar 22, 2014 3:58 pm
Thanks, appleiiguy!
I'll try that too.
Return to Linux/U-Boot
