Parallella Community • View topic - Great tool for looking at compiler generated assembly
Postby aolofsson » Fri Aug 07, 2015 11:39 pm
Ola has spun up a server with the GCC Explorer tool installed on it supporting Epiphany.
Really fast and quite useful for code optimization.
Site:
gcc.parallella.org
Blog post:
https://www.parallella.org/2015/08/07/c ... -this-out/
Re: Great tool for looking at compiler generated assembly
Postby eleitl » Sun Feb 19, 2017 2:01 pm
Thanks for the pointer. I've noticed it produces sensible-looking Epiphany assembly if fed with http://tweetnacl.cr.yp.to/software.html
Publication describing it is here https://cryptojedi.org/papers/tweetnacl-20140917.pdf
I've also successfully built https://github.com/sbp/tweetnacl-tools for ARM. The library is small enough to fit the Epiphany nodes.
While the current cores do not have crypto ISA extensions, I think they would be good crypto accelerators for the power envelope.
Notice that cjdns (which uses cnacl, but tweetnacl should be a drop-in) does build on Parallella for ARM on Paraubuntu if provided with Seccomp_NO=1 ./do.
What is still missing on Paraubuntu is ability to create /dev/net/tun
Apart from that it could be an interesting practical cjdns router, even when not using Zynq FPGA space for switch/crypto implementations.
eleitl
Postby olajep » Mon Feb 27, 2017 3:07 pm
Postby jar » Mon Feb 27, 2017 11:04 pm
Ola,
I use http://gcc.parallella.org/ occasionally. If it's not too much trouble, could you add the latest e-gcc. The current version 4.8.2 is a bit dated.
Postby olajep » Tue Feb 28, 2017 11:34 am
Return to Assembly
